Brief Description: Front Deck (Tip Up) 28: Air Inlet Vent
The air inlet vent needs to be installed now before I dismantle the forward deck. First there are two angles to make. Drawing says us 0.032 angle but I don't have any and that seems pretty thin. I have plenty of 0.062 3/4 X 3/4 angle so I'll use it.
I made the angles. I used the band saw and drum sander to make the large arc.
I installed the vents keying off the one predrilled hole in the panel.
