Brief Description: Front Deck (Tip Up) 25: Make Panel Angles
I didn't take photos but I also dimpled all the underlying structure for the top skin. I squeezed most of the holes and had to use the hand held plier dimpler on a few. This is why maybe it would have been better to not prime and rivet the center section together so earlier. Would be better to prime and rivet it now. Because I have to reclean and prime some of it now.
Next are the little angles that hold the panel on the outside edges. The drawing shows these as less than 90 degrees. One of the angles is suppose to be made of .032 angle instead of .062, probably because of squeezing it shut. But I decided to us .062 angle just like for the other brackets.
