Brief Description: Front Deck (Tip Up) 24: Dimple Firewall more
I forgot how hard it is to debur stainless steel. I ended up putting my debur bit into the angle drill and spinning it inside the firewall holes to get the burrs off. Worked great.
Then I dimpled the firewall with the squeezer. I dimpled all the underlying frame with the hand held dimpler. Some holes had to be and dimpled with plier dimpler.
