RV-7A Construction Log
RV-7A
Fuselage After Flip
3-24-2010
Front Deck (Tip Up) 26: Installed Panel Angles
These angles get drilled to the canopy deck for rivets and a #8 screw will go thru the panel into a platenut mounted to these angle brackets
Two brackets per side
From the top
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
