I finished the crotch strap work by positioning the platenuts and drilling the rivet holes. And then I drilled the 5/16 hole for the strap bolts. I match drilled with 1/8 hole then enlarged the hole using step drill. Note the note that says use right hole on co-pilot and left hole on pilot side. Crotch strap parts complete.
