Brief Description: Mid Fuselage - Bolt forward bulkhead on 1
Next I added the forward 704 bulkhead. This has to be bolted on with temporary bolts and spacers. The spacers are important because they set the distance between these two bulkheads into which the wing spar will eventually slide. If this space is to tight you won't be able to slide the wing in.
At first I tried using 6 bolts and PVC spacers but PVC is too soft and compressed. So I made aluminum spacers (see next page). And I used 4 bolts per corner.
