Brief Description: Tank Assy - Inboard Left Rib Installation 1
I finished the 5 ribs in each tank and now it is time to prepare the inboard rib. So I sanded the ribs where Proseal will go and cleaned them again with MEK. Then I installed the fittings for the vent line and return line and the BNC connector for the Capacitance Fuel Level System. I put Proseal around all the cracks. I used my brothers research on what torque values to use for the AN fittings. I used 55 in-lbs. Here are the torque values, reprinted from Ed's site.
