Sid & Houston Mayeux Project
Date: 2-12-2015
Number of Hours: 2.00
Manual Reference: Odds n Ends
Brief Description: Safety tape, stall warning, wing root fairings
I took time to knock a few odds n ends. I saw this high-strength safety tape at Home Depot Aviation Supply, so I appled it to the gas shocks holding up the canopy. I think it looks good, and helps ensure nobody smacks the strut with their foot while entering/exiting the aircraft (I hope).
Since the Dynon Skyview system features Angle of Attack, I removed the stall warning sensor from the left wing. I filled the holes with microfiber/epoxy, covered that with a non-stick mylar sheet, and taped it all in place to set. A few days later, I pulled the tape and mylar and sanded it all down. Once it's painted, it should be pretty invisible.
I also went ahead and installed the wingroot fairings just to keep the areas clean.
Safety tape on the canopy strut cylinders
Stall warning removed, holes epoxied shut
Wing root fairings installed
