Sid & Houston Mayeux Project
Date:  2-18-2015
Number of Hours:  3.00
Manual Reference:  Wingtip Lights
Brief Description:  Wingtip lights, part 1
I had originally crafted a bent oval-shaped sheet of 0.024" alclad to serve as a shiny surface to rest inside the wingtip light well, and the AeroLED wingtip lights would sit on this. However, I decided to get MUCH fancier and use sheets of mirrored acrylic which I found on the Amazon Aviation Supply website.
From the 1' x 2' x 1/4" sheet, I cut half-oval plates using the original alclad pieces as templates. I used my hand cutter to cut, and the band saw to shape and bevel. The mirror's top side was covered with a sheet of protective plastic, but the mirror side was not protected so I had to be really careful.
I had already drilled 3 screw holes into each face of the wingtip light recess, so I used those to backdrill screw holes through the mirror pieces once they were shaped to fit in place under the clear cover.
Marking the acrylic
Marking the acrylic
Cutting and shaping
Cutting and shaping
Match-drilling through the wingtip into the mirror piece
