Brief Description: New fuel line -- right wing to fuel tank valve
I finally got the rebuilt fuel line from Bonaco Hose and Fittings. This is the reattempt on the right line connecting the Andair tank selector valve to the right fuselage wall (then onward to the right wing tank). The clocking was off on the first attempt, turned 90 degrees out. This one is EXACTLY correct. I installed it, along with the Andair tank selector valve. I'm MUCH happier with this arrangement. Moving on...
