Brief Description: Main Fuel Line re-route and protection
It became apparent I'd need to reroute my fuel line from the engine-driven fuel pump to the fuel injection servo. I had the fuel line adel-clamped to the bracket that holds the engine mixture control cable, but I moved the adel clamp to the intake line just outboard from the control cable bracket (see image 1...the screw hole for the OLD clamp is visible on the white cable bracket).
Shifting this fuel line's position outboard took up some of the slack and drew the line up more tightly against the engine mount and the forward left crank case. I chose some left-over silicone hose the cover and protect the fuel lines at these two rub-points. Twist wire secures them in place.
