Sid & Houston Mayeux Project
Date:  11-25-2011
Number of Hours:  1.00
Manual Reference:  Elevator Horn
Brief Description:  Attaching the elevator horn up block
With the elevator horn up block positioned, I rechecked the elevator's up (stick aft) travel limits: 27 degrees, right in the 25-30 degree window. I drilled its rivet holes into the fuselage aft deck and riveted it in place.
Up block riveted
Up block riveted
