Sid & Houston Mayeux Project
Date:  11-23-2011
Manual Reference:  Vert stab
Brief Description:  Riveted the front attach plate to the forward spar
Back to the empennage. With all the measurements good and the vertical stab truly vertical, I match-drilled the vertical stab's forward spar and spacer plate to the attach plate using the attach plate's holes as the pattern. Debur, prime, then rivet.
Matchdrilling the plate to the forward spar and spacer plate
Primed and riveted
Primed and riveted
