Sid & Houston Mayeux Project
RV-7A
Hor Stab
Drilling forward stab, installing shims
Once the holes pilot holes were drilled, we installed the shims under the forward spar and match-drilled to 3/16" (for the AN3 mounting bolts).
Not sure why we used the duct tape, other than it just isn't a proper job unless a man can use duct tape.
Match-drilling the shims
Inboard holes drilled (note slight misalignment)
Shims drilled through
RV-7A Home
1549
Cockpit
49
135
279
92
Flight Controls
354
192
Wrap Saga A - Dream
Wrap Saga B -- Victo
Wrap Saga C -- Petit
Wrap Saga D -- Fligh
Wrap Saga E -- Emerg
Wrap Saga F -- Home
