Sid & Houston Mayeux Project
RV-7A
Brakes, Fuel Valve
Installing brake fluid reservoir and fuel tank sel
Drilled the mount holes through the firewall for mounting the brake fluid reservoir, then mounted the fuel tank selector valve to the mounting plate.
Reservoir mounted to the firewall
Aft firewall, looking fwd at the reservoir hook-up
Fuel Selector Valve, bottom view
RV-7A Home
1549
Cockpit
49
135
279
92
Flight Controls
354
192
Wrap Saga A - Dream
Wrap Saga B -- Victo
Wrap Saga C -- Petit
Wrap Saga D -- Fligh
Wrap Saga E -- Emerg
Wrap Saga F -- Home
