Started work on the cockpit fuel and brake lines, starting with the main lines from the wings to the fuel selector valve, then from the valve forward to the firewall (where it should mount to the fuel pump).
This is difficult work. Image 1 shows me trying to use the fuel bending tool to properly apply the bend in the right place. You will see later that I ultimately abandoned most of this solid tubing in favor of Bonaco flexible hoses.
