Jims Web Site
Date: 2-6-2010
Number of Hours: 2.10
Manual Reference: 6ZU2-4
Brief Description: Mounted 6ZU2-4's on back of center spar
1. For each upright, accomplished the following: 2. Positioned on spar through 1/4" hole with AN4 bolt. 3. Squared upright on spar. 4. Used a transfer punch to locate the 1/4" hole on the other end of the upright. 5. Removed upright, drilled pilot hole for AN4 bolt with #40 bit, and opened for bolt size. 6. Marked location where doubler met upright. 7. Removed upright; drew line across upright at the point marked. 8. Center punched 10 mm from line. 9. Drilled punched points with #40 bit. 10. With rivet fan, established 3 intermediate locations, and punched. 11. Drilled with #40 bit, for a total of 5 rivet locations per upright. 12. Placed upright in position, and slipped 6ZU2-5 slim under upright. 13. Back drilled through shim with #40 bit, and clecoed. 14. Used a transfer punch to locate the 1/4" hole on the other end of the upright. 15. Removed upright, drilled pilot hole for AN4 bolt with #40 bit, and opened for bolt size. 16. Replaced upright and shim. 17. Opened pilot holes for rivets with #20 bit, and clecoed.
Note: Since the dual stick modification is to be installed on this aircraft, the uprights associated with that installation were reused.
Upright in position
pilot rivet holes in upright drilled
uprights in place,and rivet holes opened
