1. Identified spar uprights. 2. Marked area to be removed. 3. Cut on bandsaw. 4. Ground edge even and filed smooth. 5. Drew centerline on part. 6. Center punched on center line 20 mm from selected end of uprights. 7. Drilled with #40 bit, then opened for AN4 bolt.
