Brief Description: Installed aileron and balance weights
1. Slipped mounting weight arm into wing. 2. Clecoed ends and center of aileron into place. 3. Installed mounting weights (5 each side) with AN3 bolts, washers, and lock nut. 4. Torqued lock nut to 25 inch pounds, per Zenith standards. 5. Verified that aileron was statically neutral with weights in place.
