Jims Web Site
Date: 2-17-2011
Number of Hours: 3.10
Manual Reference: 6ZU1
Brief Description: Added reinforcements to nose rib 1
1. Cut nose rib #1 back to allow for spar stiffner. 2. Marked 6ZU1-4 to fit rib #1.
Note: 6ZU1-4 will not fit on the inboard side of nose rib 1 and pick up the necessary mounting holes. Mounted outboard.
3. Cut 6ZU1-4 to appropriate size. 4. Clecoed nose skin in place to insure fit. 5. Created #40 pilot holes in 6ZU4-1 to mount to nose rib #1. 6. Positioned 6ZU4-1 and back drilled into nose rib 1, clecoing as each hole was drilled,using #40 bit. 7. Opened holes with #20 bit, clecoing as each hole was opened. 8;. Added bolt holes at top and bottom of 6ZU4-1. 9. Removed nose skin, 6ZU4-1, and nose rib 1. 10. Deburred parts, and primed with zinc chromate. 11. Positioned 6ZU1-5, and marked for size. 12. Cut 6ZU1-5 to match space. 13. Drilled pilot holes in 6ZU1-5 with #40 bit. 14. Positioned 6ZU1-5, back drilled with #40 bit, clecoing as holes were back drilled. 15. Back drilled bolt holes in 6ZU1-5. 16. Removed 6ZU1-5, deburred, and primed mating surfaces with zinc chromate primer. 17. Clecoed 6ZU1-4 to nose rib 1 with A5 rivets. 18. Positioned 6ZU1-4 sand nose rib, clecoing nose rib. 19. Reclecoed nose skin to nose ribs. 20. Bolted 6ZU1-4 to spar with appropriate length an3 botls. 21. Riveted 6ZU1-4 to spar with A5 rivets. 22. Removed nose skin clecos 23. Positioned 6ZU1-5 between nose ribs 1 and 2. 24. Bolted to spar with appropriate length AN3 bolts, AN960 washers and locknuts. 25. Riveted 6ZU1-5 to nose skin.
Back drilling pilot holes
Opening holes for A5 rivets
Riveting bracket to spar
