Brief Description: Connected lights and pitot tube under port seat.
1. Connected taxi and landing lights under port seat. 2. Applied aircraaft power and verified proper operation. 3. The taxi light had a disconnect behind the instrument panel which was corrected. 4. Connected strobe/position lights to strobe supply,and verified operation. 5. The position lights were reversed. Both were removed and swapped. 6. Connected pitot and static lines inside wing root and under pilot seat. A. Slipped metal tubing inside both tubes. B. Tightened fit with saftey wire. C. Sealed connection with RTV. D. Applied heat shrink tbuing to assembly. 7. Used snap ties to clean up and secure wiring and pitot/static tube. 8. Vaccummed area to remove trash.
