I managed to blow the master relay fuse. When I went to replace it, I found it was darn near impossible to do, I'd used the wire length on the fuse holder to determine the location.
I decided to make it more accessable, and while I was at it, I used a more contentional fuse holder, and placed it where it was accessable to the piloit.
1) Removed battery connections. 2) Removed existing fuse holder leads. 3) Located place for new hgolder on top of the baggage compartment. 4) Drilled hole for new fuse holder. 5) Installed new wires, spicing into the existing lead to the master switch. 6) Installed fuse holder. 7) Replaced battery connections. 8) Verified master relay operates when master switch is activated.
