Brief Description: Clecoed upper edges of 6B10-1 to lower edge of sid
1. Back drilled upper row of stbd side of side skin-lower skin interface with #40 bit. Exterior held taut by Dr. Belcher, using a small board. Clecoes installed after each hole. 2. Repeated step for lower row. 3. Repeated steps 1 and 2 for port side. 4. Removed staps holding skins in position. 5. Back drilled holes in upper and lower rows on both sides which were covered by the strap. Used #40 bit.
Stbd side back drilled with #40 bit
Interior of port side after drilling with #40 bit.
