Brief Description: Connected baggage side supports to baggage floors
1. Placed side to side support angles in position and clecoed to side support angles. 2. Placed baggage floor in position above these supports. 3. Drilled "key" holes along side into floor with #40 bit. 4. Removed baggage floor, side to side support angles, and side supports. 5. Clecoed side supports to key holes in baggage floor. 6. Back drilled remaining holes in baggage floor with #40 bit. 7. Replaced side supports and side to side supports in aircraft, clecoing in place. 8. Replaced baggage floor, clecoing in place to verify pilot holes along side have alignment. 9. Removed baggage floor, side supports, and side to side supports. 10. Clecoed side supports to baggage floor. 11. Opened pilot holes between side supports and baggage floor with #30 bit for A4 rivets.
