Jims Web Site
Date: 7-4-2012
Number of Hours: 18.00
Manual Reference: (none)
Brief Description: washed, prepped, and painted wings
As wings were removed from fit check, they were placed on saw horses for plaint.
1. Scrubbed top of port wing with MEK solution to remove grease and misc surface coatings. 2. Washed with high pressure washer. 3. Dried, and recleaned grease areas with MEK. 4. Washed with high pressure washer. 5. Dried, and turned wing over. 6. Repeated steps 1-4 for bottom of wing. 7. Sprayed wing bottom with FP202 Etch Primer. 8. Allowed to cure, then turned port wing over. 9. Sprayed wing top with FP202 Etch primer. 10. Allowed to cure, then taped and covered future red areas with sheet plastic. 11. Painted white areas with basecoat. 12. Allowed to cure, then removed tape and plastic. 13. Covered white areas with tape and plastic sheeting. 14. Painted red areas with basecoat. 15. Allowed to cure, then removed tape and plastic. 16. Painted with FC720 clear overcoat. 17. Allowed to cure overnight, then turned wing over. 18. Repeated steps 10-16 for bottom of wing. 19. Repeated steps 1-18 for starboard wing.
Wing positioned on saw horses
washing wing
spraying white coat
