RVGator
Date:  6-8-2012
Number of Hours:  1.25
Brief Description:  Sanded & refilled rivets
Not much time in the shop the last two days, Anita has been ill and I had some pipe leaks to fix. I did sand off the filler on the rivets and apply another layer. Hopefully I can get the skirt and the windscreen primed soon then I will move things to the airport. I need a new hot water heater and the plane is in the way. It seems the anode in my heater is gone and now has started to corrode my copper pipes from the inside. So my next project after the plane is done is to re-pip the house with PEX!
