Brief Description: Filled rivet holes, faired handle area
After taping up the canopy with good tape that I hope will not allow primer of resin to bleed under, I filled the rivet holes with a flox mix. I also removed the canopy handle in order to fair the skirt to the brass bushing I used as an extension. This should keep rain from getting inside.
