Brief Description: Part 1 Another coating of epoxy
I coated the skirt with epoxy to start the day off, that was after letting the heater run for a while to warm up the shop. I later read that I should not use the polyester filler the way I did, putting some on and sanding off all of it except what fills the pin holes is okay but I used it to fill a couple of low spots. Now I have to decide to leave it or take my chances and until it goes to paint and let the painter sand it down. Hmmm.
Oh I later added a second coat after the first firmed up, some type of dust or debris got into the surface. :) I am not sure what it is from, it is almost like it came from the foam roller I was using. More sanding!
It looks beautiful except for the grit :(
White stuff is polyester filler I guess I am not supposed to use this much of
