Brief Description: 1. Shimmed vertical parts of skirt
More work but not a lot of progress. I need some shims on the vertical ribs of the canopy frame, if I cleco it as is this pulls the skirt and distorts the bottom edge. I decided to mix up some resin with micro balloon mix to use as a liquid shim. I put duct tape on the places the shim is required and then waxed the tape to ensure the resin would not stick. I the applied the resin paste and clecoed on the skirts. After it dries I should have a nice shim attached to the skirt side.
