Well it is hard to believe another year has passed. This time last year I anticipated having the plane flying by now but this year is it!
I worked on how to glass the form I made a couple days ago. After pondering how to apply the glass I laid out the patter onto the plastic then put the glass under it and applied the resin. After letting it soak I used a squeegee to remove the excess resin and then I cut out the pattern and started to apply on the layers. The glass I have was a bit tough on the curves even though it is BID glass. We will see how it turns out.
