I spent most of the day getting ready to go back to work but I did manage to get some riveting done on the baggage door. I first dimpled and machine countersunk the hole as required. Then I back riveted the outer rib. The forward and aft ribs will need get riveted with the rivet set and bucking bar. The only rivets I will be able to set with the pneumatic squeezer will be the rivet common to the hinge.
