I moved on to making the purge return line. I decided to keep the bulkhead fitting low on the fire wall near where the main fuel supply goes. After fighting with trying to make the purge return line in one piece I gave up. I had the tough part done which was the part that goes under the side console. Once I decided to go with a two piece line I had to make some form of support for the small ¼” line. I had some Delrin rod laying around so I drilled holes for two lines, but 3 grooves to retain some zip ties and then cut it in tow. Now I sandwich the lines between the two halves with some plastic tape around the line to protect them. It was late and I already missed the first half of the Florida vs. Mississippi State game so I called it a night.
Test fit of fuel line support
Intitial fitting, I will add two more zip ties once the foward half is made.
Line is goes into T fitting that is the left tank supply side of the fuel selector.
