Well after supervising the carpet installation I got down into the shop for a couple of hours work. I worked on the left brake line the goes from the center coupler around the cockpit and to the fitting that goes down through the gear weld mount. I was amazed that I did this one right the first time. My only concern is making the last flare on the upper part of the line, I could not get the tube all the way into the flare stop due to the sleeve interfering. I think the flare meets tolerances but I will have the EAA tech guy over one of these days sometime soon to do another check of my work, I will get his opinion and go from there. If I do have to make a new line it will be easy now that I have one made. It is far easier to copy than to make one of these lines. I think what helped with this line is I used a coat hanger to approximate the line shape.
The brake line goes from the fitting on the right side of the picture.
Connected to fitting going out the bottom of the plane to the wheel
