Brief Description: Right fuel supply line and vent lines
Well I am back to work on the plane. I took a couple of days to recover from the jet lag after my last string of days flying. I began trying to fabricate the fuel line that goes from the right tank to the fuel selector. I almost had it the last time I worked on it but today it was like starting over. At any rate after several hours and what seemed like miles of tubing I have the line done. Actually I still need to flare the end and attach it to the selector. I wanted to practice some more flaring before I flared the actual line. All I need now is to screw up the flare and then have to make the whole line over again. After some practice flares I decided to finish up the fuel vent lines. I flared and attached the external piece of the two piece vent line only to find it was just a bit short. I did not take into account the flare when I measured. I made up two more and in no time had them flared and installed. They are just finger tight right now, I still need to make a screen for the ends to keep the bugs out of the line. A long day but I think I have completed the line that will give me the most trouble. The other lines will be fairly short, at least for the fuel system. The brake lines will be long but the ΒΌ in line is easier to work with.
Right vent line
Left vent, I still need to install the plastic bushings on both sides
