Well more work putting things together, hopefully for the last time. The anchor I glued on yesterday was set so I tied the static line âTâ to it and then capped the fitting and installed my quick release tube. None of this is required but this will make a nice access point for checking the static system for leaks. I then clamped the fresh air hose to the vent after making sure the vent was nice and tight.
I spent more time working on some fuel line stuff on the engine but that was it for the day.
Pull stirped tube to release fitting, easy place to connect test equipment.
