I spent some time figuring out where to mount the 496 GPS antenna and XM Wx antenna. My plan is to drill a couple holes so that heat from the instruments can escape at the top, this will do double duty, it helps cool the instruments and also will act to defrost the windscreen. I will use one of these holes to run the wires from the antennas.
