With the last bit of time in the shop I worked on a paper template for a bracket that will hold the fresh air and heater hoses. I wanted to get this done before I put the plane on the landing gear. The top hole will support the fresh hose air that comes from a vent on the forward left side of the fuselage and then the runs up to the left subpanel. Heat gets pulled from the firewall heat valve to an eyeball vent that will be below the fresh air hose on this bracket, the control cable to control the amount of heat will be just below the heat eyeball vent. Not a bad start, I will now have to figure out a support structure tomorrow.
