I flared the other ends and installed the AN fittings and the brass tube fittings the Safe Air plastic tubing will tie into each end of the hard lines.
I spent about and hour trying to decide on a location for the Instrument Panel Ground Bus. I will continue this later
Upper portion, you can see the cap over the nylon block
Test fit the console cover, you can see an extra support I made to hold tube in the middle of the run.
