I worked on the hard pitot and AOA lines that run under the left console. I flared the rear end of the tubes. In test fitting the tubes the nylon block I am using at the top for support moves a bit when the screw is tightened down. I made a cap out of aluminum to go over the block. Pictures on next entry
