Brief Description: Part 2 Re-installing contols rods
After getting back from the store I decided I needed to get the control rods back in place. This took much longer than I thought, the first time these were fit the aft top skin was not installed, it takes some doing to get all those washers and nuts in place when you are working in that tiny tunnel. After an hour and a half I finally had the main bell crank installed and the lower rod connected to the bell crank. I did not torque the bell crank yet, I was going to wait to buy the pitch servo for the autopilot until later but this is such a pain to get to I think I will order it now so the install can be completed now rather than taking this stuff apart again later.
