Wow it seems forever since I have done any work. I got back day before yesterday from a trip and after the required “get over jet lag day” I decided to tackle the skirts. I drilled the left and right skirts to the fuselage. They lay on nicely for the most part but the aft ends had to be pulled down. I do get a bit of lifting right where the skirt curves up aft of the rear seat bulkhead, I have read that this is common. I still need to cut and fit the very aft part but before I do I need to solve one problem I noted. I thought I did a good job of fitting the frame to the fuselage sides but the aft end bulges out just slightly. I need to find a way to compress this area in a bit; this might help make the lifting further aft settle down some. I will have to see what I can come up with.
Aft end needs fitting still
Side looking forward you can see the bulge where the frame is too wide.
