As usual I took day to get over my jetlag so today was my first day to get some work done. I did not do much but every little bit helps. I drilled n ¾” hole in the area just aft of the right cabin support. This will allow wires to run to the ground block in the battery well. This will also be the route for any wires that will run out to the wings. Before I can start the wire process in earnest I need to finalize my right console switch arrangement. I decided to put the ELT control module on the right console. One thing I did not think of until today where dimmer switches. I will have a main instrument panel led strip, then and front led strip on both sides as well as a two rear led strips on both sides.
