RVGator
Date: 10-26-2009
Number of Hours: 2.75
Brief Description: P-Mag push buttons
I did not do much today, I had other stuff to take care of and really just wanted a break. I stopped at an electronic supply shop looking for some push button switches for the power test to the P-Mags. The smaller ones I liked were only .25 amps which would not work since it is a 2 amp circuit. I did find some metal ones that I am going to try, they are push button, momentary, normally closed switches, and they fit the same hole as the toggle switches. To test the P-Mags internal alternator you momentarily remove the 12V power going to it, if the engine continues to run then the internal alternator is functioning, hence the “normally closed” switch, a push of the button will open the circuit, release and it operates normally. The best part is the switches were only $7. I temporarily installed all of the switches to give them a test drive. I bought some rubber boots to go over the push buttons but I don’t like how they look. I will find some type of vinyl cover, maybe paint them, or leave them as is, hey there is a thought! The top two switches are Battery/Main Alternator on the left, Standby Alternator on the right. The bottom row is the left and right P-Mags with the test button for each next to its respective switch. The toggles stops the P-Mag from sending a spark to the plugs, the mag check is just like normal mags.
I still needed to tie the diode to the main bus, so I tackled that project. After it was all done I wanted to test the function of the diode. With the main bus powered the voltage read 13.72 V on the main bus and 13.44 V on the E-bus. The diode causes a slight voltage drop. I then powered the E-bus as it would be using the alternate power feed switch and it did in fact only power the E-bus, there was a slight voltage reading on the main bus of only 0.4 volts.
With rubber boots on puttons
Ilike them better without
Jumper accross two terminals of the diode the to the main bus.
