Today was a day, which is usually the case when I have to leave for work the next day. I have an 8 day trip followed by a 4 day trip. I installed some dehydrator plugs into the upper spark plug holes on the engine; I picked these up from Aircraft Spruce. I wanted 14 mm plugs, which is the automobile plug size but Spruce did not carry them and all of the other sites I found did not seem to have them. I have the adapters that go into the 18 mm holes so it was just a matter of removing them. I will not get to my engine as soon as I had hoped so I thought the dehydrator plugs were a good idea.
The EZ Nuts instrument mounting bezel also came in the same order so I test fit the G-meter. This is sure a no fuss way to install an instrument. As it turns out this will be the only round dial in my panel.
Dessicant turns pink when moisture is collected. Flash washed out the blue color
EZ Nut bezel sticks to the back of the instrument.
