With the trouble had with the left bottom skin I decided to see if I was going to have issues with the right side. Well after a little effort the right skin seems to fit just fine. There are a handful of holes that I just could not get clecos into but the rest went well, and I do not have a gap between the leading edge skin and the bottom skin. I still need to try some new cleco sequence to see if I can get the left side to fit better. For now I am not going to worry about it until it is time to drill the skin to the wing.
I also set the remaining rivets on the outboard aileron bracket that goes on the wing.
