I really did not accomplish anything today. I went in today with the idea of safety wiring the prop bolts; you are to do them in pairs. Well the idea is you wire such that the wire is pulling the bolt tight so if you are over the top of one bolt then you need to get to the back of the next. Well the space between the nut and the hub is so small you can’t get a twisted .032 safety wire in there. I gave up on this for now and turned to the oil door.
After nooddling on this for a while I gave up since I need to look up two things online
