I was kind of all over the place with my work today. I final installed the ring that holds the filter mounting plate to the fuel control air inlet then I hooked up the purge valve line. I am using a rod end bearing on this connection for extra security. I pinched cable wire would work but there is too much chance that it might break or work loose. If the purge valve moves to the off position on its own the engine stops!
The last part of the day was spent trying to figure out how the spark plug wires should be routed and organized.
