Brief Description: Prepared for wing install tomorrow
I plane to fit the wings tomorrow so I gathered the hardware and inspected everything I thought I would need. I cut down the wood board used as a temporary floor to gain access to the aft side of the spar. I tested the tools to see if I can get onto the bolts, I think I will buy some cheap open end wrenches to grind down to make a better fit.
I disconnected the long aileron push rods to keep them out of the way.
Gound wire to ensure fuel gage gets a good reading
Bolts set up left rigth top bottom put washer on bottom bolts so I would not forget
