Brief Description: 2. Drilled bolt hole in tank supports
After getting a hand bolting the bracket to the fuselage I drilled the ¼” hole through the tank brackets, a slot will go into the tank side once the wings come off. The slot is put there so that if the wing hits something hard it will rip away instead of ripping out the side of the fuselage.
