Well I am behind with my log entries. I am now working from the hanger so it is less convenient to load pictures like it was when I could just go upstairs, and frankly I am trying to work more. Of course there has been a lot to do with the move to the hanger.
At any rate in my quest to get the wings fit I worked on making the fuel tank support brackets. The “A” model is different from the straight -8 but I think I did a pretty good job. It took over 2 hours to make the first one and about and hour to make the second. I have the holes marked but no drilled at this point. I may adjust the location based on where my wire and fuel lines run in the fuselage.
